Model 2900 XL Professional - rev A.10.0 to A.10.8
A.10.0
- add 660ft speed detection and printout
- convert output tree bits to blue light use
- change to XLW scoreboard protocol
- add flash storage of parameters
- add scoreboard bits storage
A.10.1
- add negative sign to RT
- update output method to scoreboards
A.10.2
- detect redlight tree update limit to once
A.10.3
- lock autostart on once process enabled
- insert code to detect end of bracket
A.10.4
- skip 1320 sensor check if 660 end
- verify valid command for internal commands
- update outpur to PC for xmit completion
- loop one more time if 660 end to insure 660 et is processed
- require both prestage to turn red/green off in autostart
- store additional settings in flash memory
A.10.5
- add win indicator
A.10.6
- fix 1or 2 redlights, full/pro/.4/.5
A.10.7
- add scoreboard blanking command to start tree command
- add CR to end of align transmission for improved integrity
- fix ET not zero in LBY lane
- fix removal of 660, 330 or 60 in practice/qualify/elims
- fix intermittent crosstalk added wrong if right lane last to leave
A.10.8
- add transmission integrity check for output of dialin delay to tree
A.10.1
A.10.2
A.10.3
A.10.4
A.10.5
- add win indicator
A.10.6
A.10.7
A.10.8
