Where can I download the current FTDI drivers?
Fri May 18, 2018 6:05 pm
The current FTDI drivers for RaceAmerica product numbers 4520A/A2/A4/U, 4620A/A2/U, 45232A/B, 45485A can be downloaded at the link below.
*** RIGHT CLICK THE LINK BELOW TO OPEN IN A NEW TAB ***http://www.raceamerica.com/drivers/ftdi_setup.zip
Re: Where can I download the current FTDI drivers?
Tue May 22, 2018 6:36 am
When installing FTDI drivers, the software installation is a two step process. The installation begins with install of the USB driver, then the second step is install of a serial port driver, both contained in the FTDI install program.
When the installation is complete, plug in the USB Wireless Unit and wait a few minutes until Windows assigns a COM port number to the device. The COM port is used by software programs to communicate between Windows and the USB hardware.
Fri May 25, 2018 4:44 pm
Will these drivers work with all versions of Windows OS?
Fri May 25, 2018 4:51 pm
These are the latest drivers and are fully compatible with Windows 7, 8, or 10 and the latest FTDI chips. Older Windows will load these drivers but performance ranges from unreliable to not fully compatible. There were two sets of FTDI drivers in the past and were mostly dependent on the revision of the FTDI chip inside the hardware being installed.
Thu Mar 05, 2020 10:26 pm
by Riyaaa
Hi!
Well shared topic. Throughout this thread got excellent information!
Thank you!
