4520 wireless unit power requirements
Postby Richkim » Wed Oct 31, 2018 10:42 am
I set up our PC with the control software and the 4520 wireless black box unit. I could not find the AC adapter to power the black box up. Is there somewhere I can find a spec on the AC adapter and connector size for this unit?
Re: 4520 wireless unit power requirements
Postby raceamerica » Wed Oct 31, 2018 2:23 pm
There are several models of 4520's and the international models 4620.
4520U/4620U connect to a PC USB port and gets its power from the USB cable, no additional AC Power Adapter required.
4520A2/4620A2 connect to a RS232 device like a printer or a LED display. These units take a 9VDC-12VDC 300mA min. AC Power Adapter with a 2.1mm barrel connector.
4520A4/4620A4 connect to a RS422 device like a large LED display. These units take a 9VDC-12VDC 300mA min.AC Power Adapter with a 2.1mm barrel connector.
Postby Richkim » Wed Oct 31, 2018 2:28 pm
Same AC Adapetr is used for everything but the USB wireless unit, rIght?
Is the same antenna used for all these models as well?
Postby raceamerica » Wed Oct 31, 2018 2:31 pm
Yes, same AC Adapter for non-USB models of both 4520 ans 4620. Antennas is the same for all 4520 900MHZ units and a different antenna for all 4620 2.4GHz models.
