by raceamerica » Mon Jun 04, 2018 2:20 pm
You could use the track safety cube for pit in pit out but they would be much smaller than typical RaceAmerica track safety lights. To insure the two wireless hand controllers do not interfere with each other, check the Optimizer Code on each, they need to be different. The wireless hand controller for the track will control only the track safety lights while the track safety cubes will be controlled by the second hand controller.
If the Optimizer Code on both wireless hand controllers is the same, both hand controller will control track safety lights and cubes at the same button press. Highly doubtful the Optimizer is the same but is a good reality check. The Optimizer Code is the key to what channel and transmit code is sent by each wireless hand controller and which safety light or cubes will respond (with matching Optimizer Codes).
